Loading a track
Before you can start mixing, you’ll need to load music onto a deck. djay makes this quick and flexible, giving you several simple ways to get a track ready to play. Loading a track is the first step to getting the music flowing.
Loading a track
How to load a track onto a deck​
  • Right-click on a track and select Load on Deck 1.
  • Drag and drop the track directly into Deck 1.
  • Double-click a song to load it onto the next available deck.
The chosen track will begin playing automatically when it is loaded. To stop tracks playing automatically, go to Settings > General and turn off Start Playback.
Make sure the crossfader is set to the left (toward Deck 1) so you can hear the track.
How to access additional track options​
Click the artwork next to the waveform of your loaded track.
Track options
  • Double: Loads the same track on both decks. Perfect for experimenting with transitions, beat juggling, or learning a song’s structure.
  • Load next/load previous: Quickly switch to the next or previous track.
  • Scratch tools: Instantly loads a scratch-ready track from djay’s built-in scratch tools.
  • Add to queue: Adds the track to your queue.
  • Eject: Unloads the track from the deck.
