How to find your djay Pro data and move it to a new device
This guide explains where djay Pro stores playlists, cue points, MIDI mappings, recordings, and other user data on macOS and Windows — and how to move that data to a new device.
- macOS
- Windows
djay Pro (current version) & djay Pro AI (3.x/4.x)
App Data is stored in:
~/Music/djay/
This folder includes:
- djay Media Library: playlists, history, queue, and all per-song metadata like cue points and loop regions
- Backups: automatic backups of the djay Media Library
- Key Bindings: custom keyboard shortcut sets
- MIDI Mappings: custom MIDI controller mappings
- Recordings: audio and video recordings
- Samples and Sampler Presets: custom samples and sampler presets
Track analysis data is stored in:
~/Library/Group Containers/VJXTL73S8G.com.algoriddim.userdata/Library/Application Support/Algoriddim/
djay Pro 2
~/Music/djay Pro 2/
- djay Media Library: playlists, history, queue, and song metadata
- Backups: automatic backups of the Media Library
djay Pro 1
If you downloaded djay Pro from the Mac App Store:
~/Library/Containers/com.algoriddim.djay-pro-mac/Data/Library/Application Support/Algoriddim
If you downloaded djay Pro from the Algoriddim website:
~/Library/Application Support/Algoriddim
- djay Preset Library.plist: cue points, downbeats, and other user data
- Metadata: analyzed song data (waveforms, beat grids, etc.)
- Sets: DJ set history as shown in the djay Pro Media Library
- Samples & Sampler Presets: custom audio samples and presets
- Video Effects: custom overlays for video mode (text or image)
Move djay Pro to a new Mac
- Locate the folders shown above for your installed version of djay Pro.
- Copy these folders in full (for example: djay, Backups, metadata folders).
- Install djay Pro on the new Mac.
- Quit djay completely.
- Paste the copied folders into the same locations on the new Mac.
- Open djay — your playlists, cue points, settings, and history will appear automatically.
Ensure djay is closed before moving data.
Copy full folders rather than individual files for best results.
%HOMEPATH%\Music\djay
- djay Media Library: playlists, history, queue, cue points, and loop regions
- MIDI Mappings: custom controller mappings
%LOCALAPPDATA%\Packages\59BEBC1A.djay_e3tqh12mt5rj6\LocalCache\Local\Algoriddim\djay\Metadata
App settings and caches are stored here:
djay Pro (legacy versions)
Windows Store version:
%LOCALAPPDATA%\Packages\59BEBC1A.djayPro_e3tqh12mt5rj6\LocalState\Library\Algoriddim
Demo version:
%LOCALAPPDATA%\Packages\Algoriddim.djayPro_ysvet2nbq0e5e\LocalState\Library\Algoriddim
- djay Preset Library.plist: cue points, first downbeats, and other custom data
- Metadata: song analysis data (waveforms, beat grids, etc.)
- Sets: your DJ set history
Move djay Pro to a new Windows PC
- Locate the folders listed above for your version of djay Pro.
- Copy these folders in full.
- Install djay Pro on the new computer.
- Quit the app completely.
- Paste the copied folders into the same file paths on the new device.
- Relaunch djay — your data will load automatically.
