Understanding headroom, gain, and the limiter in djay
Learn how headroom, gain, Auto Gain, channel meters, and the limiter work together in djay to help prevent clipping and maintain clean audio output.
djay processes audio internally using floating point processing, which provides a very large amount of internal headroom. This means audio inside djay can be processed without clipping internally. Clipping can only occur when the final signal is sent to an external audio output, sound card, DJ controller, or mixer.
The headroom setting lowers each deck’s level before the audio is sent out of djay, giving extra space to prevent clipping. The limiter helps prevent audible distortion if the signal gets too loud.
What is headroom?​
Headroom is the amount of extra space available before an audio signal reaches the maximum output level and may clip.
In djay, the headroom setting reduces the signal level before it reaches the final output stage. This helps prevent clipping when multiple decks, EQ boosts, FX, loops, or other processing increase the total signal level.
For example:
  • No headroom keeps the output level as high as possible.
  • -6 dB headroom lowers the signal slightly to create safety margin.
  • -9 dB headroom creates more safety margin, but also lowers the output level more noticeably.
Watch the video below with sound on to hear how different headroom settings affect the audio level in djay.
Using more headroom can make djay’s output sound quieter compared to another app, hardware player, or mixer channel using a different gain structure.
What is Auto Gain?​
Auto Gain helps keep tracks at a consistent reference level by automatically adjusting the deck gain for each track.
This is useful because different music files can have different loudness levels. Auto Gain helps balance these differences so transitions sound more consistent and FX receive a predictable input level.
For most users, we recommend leaving Auto Gain enabled.
Gain is intended for matching the level of different tracks to each other. It should not be used as a replacement for master volume or external mixer gain.
Why does changing headroom affect the channel meters?​
In djay, channel meters are designed to show whether the signal is approaching the clipping point after accounting for the selected headroom value.
Because djay factors the selected headroom setting into the channel meter display, changing headroom can also change how the channel level appears on the meter. This helps ensure that the red area continues to represent the clipping point for the current headroom setting.
The channel meters are measured before the channel fader, but djay subtracts the selected headroom value from the meter display so that the red area still represents the point where clipping could occur at the final output stage.
This means:
  • The meters help show whether your signal is safe for the selected headroom setting.
  • The red area still indicates that the final output may be too hot.
  • The channel meter does not show the actual final output level, because it does not include the line fader, crossfader, or post-fader FX.
  • Lowering the headroom value can make the meters appear higher.
  • Increasing the headroom value can make the meters appear lower.
Where does headroom sit in djay’s signal flow?​
For a standard deck, djay’s signal flow can be simplified as follows:
  1. Neural Mix, Gain, pre-fader FX, EQ, and Filter
  2. Channel meter
  3. Line fader and crossfader
  4. Post-fader FX
  5. Headroom attenuation
  6. Main output or individual deck outputs (depending on the selected mixer mode)
Headroom is applied after the deck’s fader and post-fader FX processing, before the signal is sent to the final output.
How djay prevents clipping​
djay uses floating point processing internally. This gives djay a very large amount of internal headroom, so audio inside djay does not clip or distort if a signal temporarily becomes louder during processing.
Clipping can only happen when the audio is sent out of djay to an external output, such as:
  • Your device speakers
  • An audio interface
  • A DJ controller
  • An external mixer
To help prevent audible digital clipping, djay includes a transparent limiter. The limiter is designed to prevent harsh distortion when the signal exceeds 0 dBFS, while changing the sound as little as possible.
For most users, we recommend leaving the limiter enabled as a safety net.
For most setups, the default settings work well:
  • Limiter enabled
  • Auto Gain enabled
  • Headroom set to 0 dB
These defaults provide a good balance between clean audio and a reasonably loud output signal.
You may want to adjust these settings depending on your setup:
If you want the cleanest possible audio​
Increase the amount of headroom if your channel or output meters regularly touch the red during normal playback.
For example, try -6 dB or -9 dB headroom and check whether the meters stay in a healthy range while playing your music.
If you are using an external mixer​
If the signal from djay is landing too hot on the external mixer’s channel meters, increase the amount of headroom in djay until the signal sits in a healthy range.
As a general guideline, the signal should stay mostly in the green and only occasionally reach the orange.
If you need more output level​
If djay’s output level is too low, first check whether you can increase the level on your audio interface, controller, mixer, or PA setup.
If the level cannot be increased elsewhere, you can reduce the amount of headroom in djay to increase the output level.
For example, changing from -9 dB headroom to -6 dB or 0 dB will increase djay’s output level.
djay also includes +3 dB and +6 dB headroom options for situations where more output level is absolutely necessary and the level cannot be increased elsewhere in the setup.
Use these settings carefully. They reduce the available safety margin and can make the limiter work harder, which may reduce audio transparency if the signal is pushed too far.
When reducing headroom or using positive headroom values, keep the limiter enabled and watch the meters carefully.
Why djay may sound quieter than another DJ app or hardware player​
Different DJ apps and hardware players use different gain structures, limiter behavior, meter calibration, and output levels. Because of this, djay may sound quieter or louder than another system even when using the same tracks and similar mixer settings.
Output level can also depend on the connected hardware. Some DJ controllers and audio interfaces have lower physical output levels than others.
If djay sounds quieter than another source connected to the same external mixer, try the following:
  1. Confirm that your controller or audio interface output level is set correctly.
  2. Check the selected headroom setting in djay.
  3. Make sure the deck gain is set appropriately. If in doubt, use Auto Gain.
  4. Increase the input gain on the external mixer if needed.
  5. Make sure the signal does not regularly hit the red.
  6. Leave the limiter enabled to help prevent audible clipping.
When comparing output levels, use the same mixer channel and similar source material whenever possible. This makes it easier to identify whether the difference comes from djay, the connected hardware, the mixer channel, or the track itself.
External mixer mode and individual outputs​
When using an external mixer or individual deck outputs, djay routes decks to the mixer individually.
Each deck is sent to a separate mixer channel instead of being summed inside djay. The final gain staging then also depends on the external mixer’s input gain, channel fader, master level, and output section.
Best practices for clean audio​
To maintain a clean signal:
  1. Keep the limiter enabled.
  2. Keep Auto Gain enabled for consistent track levels.
  3. Use headroom to create safety margin when needed.
  4. Avoid running the meters into the red during normal playback.
  5. Use EQ boosts carefully.
  6. Use deck gain mainly to match the level of different tracks.
  7. Use master volume, headroom, and your external mixer or audio interface to manage the final output level.
A good setup should provide enough output level while still leaving space for louder sections, EQ changes, FX, and transitions.
