How to find your djay Pro data and move it to a new device
This guide explains where djay Pro stores playlists, cue points, MIDI mappings, recordings, and other user data on macOS and Windows — and how to move that data to a new device.
djay Pro (current version) & djay Pro AI (3.x/4.x)
App Data is stored in:
~/Music/djay/
This folder includes:
  • djay Media Library: playlists, history, queue, and all per-song metadata like cue points and loop regions
  • Backups: automatic backups of the djay Media Library
  • Key Bindings: custom keyboard shortcut sets
  • MIDI Mappings: custom MIDI controller mappings
  • Recordings: audio and video recordings
  • Samples and Sampler Presets: custom samples and sampler presets
Track analysis data is stored in:
~/Library/Group Containers/VJXTL73S8G.com.algoriddim.userdata/Library/Application Support/Algoriddim/
djay Pro 2
~/Music/djay Pro 2/
  • djay Media Library: playlists, history, queue, and song metadata
  • Backups: automatic backups of the Media Library
djay Pro 1
If you downloaded djay Pro from the Mac App Store:
~/Library/Containers/com.algoriddim.djay-pro-mac/Data/Library/Application Support/Algoriddim
If you downloaded djay Pro from the Algoriddim website:
~/Library/Application Support/Algoriddim
  • djay Preset Library.plist: cue points, downbeats, and other user data
  • Metadata: analyzed song data (waveforms, beat grids, etc.)
  • Sets: DJ set history as shown in the djay Pro Media Library
  • Samples & Sampler Presets: custom audio samples and presets
  • Video Effects: custom overlays for video mode (text or image)
Move djay Pro to a new Mac
  1. Locate the folders shown above for your installed version of djay Pro.
  2. Copy these folders in full (for example: djay, Backups, metadata folders).
  3. Install djay Pro on the new Mac.
  4. Quit djay completely.
  5. Paste the copied folders into the same locations on the new Mac.
  6. Open djay — your playlists, cue points, settings, and history will appear automatically.
Ensure djay is closed before moving data.
Copy full folders rather than individual files for best results.
