djay Pro stores data in the following locations. To access these folders, activate the Finder, select "Go To Folder..." from the "Go To" menu, and copy & paste the respective path below.
djay Pro AI
App Data:
~/Music/djay/
This folder contains the following data:
- djay Media Library: playlists, history, queue, as well as all per-song metadata like cue points and loop regions
- Backups: automatic backups of "djay Media Library"
- Key Bindings: custom keyboard shortcut sets
- MIDI Mappings: custom MIDI controller mappings
- Recordings: audio and video recordings
- Samples and Sampler Presets: custom samples and sampler presets
Track analysis data:
~/Library/Group Containers/VJXTL73S8G.com.algoriddim.userdata/Library/Application Support/Algoriddim/
djay Pro 2
App Data:
~/Music/djay Pro 2/
djay Pro 1
If you downloaded djay Pro from the Mac App Store:
~/Library/Containers/com.algoriddim.djay-pro-mac/Data/Library/Application Support/Algoriddim
If you downloaded djay Pro from the Algoriddim website:
~/Library/Application Support/Algoriddim
- djay Preset Library.plist: cue points, first down beats and all other data set by the user
- Metadata: per-song analyze data (e.g. waveforms, beat grids, etc.)
- Sets: your DJ set history as displayed in the djay Pro media library
- Samples: custom audio samples (including recorded samples)
- Sampler Presets: custom audio sampler presets
- VideoImageEffects and VideoImageEffects.plist: custom image overlays for the djay Pro video mode
- VideoTextEffects.plist: custom text overlays for the djay Pro video mode
Note: To move djay Pro to another Mac, simply copy these folders to the same location on the new Mac.
