While Neural Mix™ was designed to work best with the Apple Bionic chipset’s Neural Engine processor, the feature will also work on certain older devices that support iOS 12 and have sufficient processing ability.
Neural Mix™ will work on these devices:
- iPhone 7 or later
- iPhone SE (2nd generation or later)
- iPad (6th generation or later)
- iPad Pro
- iPad Air (3rd generation or later)
- iPad mini (5th generation or later)
- iPod Touch (7th generation or later)
For the best experience when using Neural Mix™, we recommend using devices with Apple Bionic chipsets:
- iPhone XS or later
- iPad Pro 11‑inch
- iPad Pro 12.9‑inch (3rd generation or later)
Note: Neural Mix™ requires a PRO subscription and is included for all existing subscribers.
