Neural Mix device compatibility and quality levels
This article outlines Neural Mix compatibility across all supported djay platforms and explains how quality levels adjust automatically based on your device’s processor and operating system.
Introduction​
Neural Mix lets you isolate beats, instruments, and vocals in real time using advanced AI. The available quality level varies depending on your device’s hardware and operating system. djay automatically selects the highest quality your device can support.
You can check the supported quality on your device in djay settings under "Advanced".
Neural Mix is fully supported on Apple Silicon Macs and also works on Intel-based models. It automatically adjusts to the highest quality that your Mac can handle.
For the best performance and quality, Apple Silicon is recommended.
Quality levels​
Maximum Quality (100%) – Macs with Apple Silicon (M1 or later)
High Quality (80%) – Intel-based Macs
Exclusive features for supported devices​
  • Neural Mix Automix transition
  • Neural Mix Crossfader FX
