Neural Mix device compatibility and quality levels
This article outlines Neural Mix compatibility across all supported djay platforms and explains how quality levels adjust automatically based on your device’s processor and operating system.
Introduction
Neural Mix lets you isolate beats, instruments, and vocals in real time using advanced AI. The available quality level varies depending on your device’s hardware and operating system. djay automatically selects the highest quality your device can support.
You can check the supported quality on your device in djay settings under "Advanced".
- macOS
- iOS
- Windows
- Android
- VR platforms
Neural Mix is fully supported on Apple Silicon Macs and also works on Intel-based models. It automatically adjusts to the highest quality that your Mac can handle.
For the best performance and quality, Apple Silicon is recommended.
Quality levels
Maximum Quality (100%) – Macs with Apple Silicon (M1 or later)
High Quality (80%) – Intel-based Macs
Exclusive features for supported devices
- Neural Mix Automix transition
- Neural Mix Crossfader FX
Neural Mix uses Apple’s Neural Engine for real-time stem separation. djay automatically selects the appropriate quality level for each device.
Quality levels and supported devices
- iPhone 11 or later, iPhone SE (2nd gen or later)
- iPad (10th gen or later)
- iPad Pro 11" (3rd gen or later)
- iPad Pro 12.9" (5th gen or later)
- iPad Air (4th gen or later)
- iPad mini (6th gen or later)
High Quality (80%)
- iPad (9th gen)
- iPad Pro 11" (1st–2nd gen)
- iPad Pro 12.9" (3rd–4th gen)
Medium Quality (70%)
- iPhone 7–XR series
- iPad (6th–8th gen)
- iPad Pro 9.7", 10.5", 12.9" (1st–2nd gen)
- iPad Air (3rd gen)
- iPad mini (5th gen)
- iPod touch (7th gen)
Exclusive features (A12 Bionic and later)
Neural Mix is supported on Windows systems and automatically adjusts based on your computer’s performance. Quality may vary depending on your processor and system configuration.
Quality levels
Maximum Quality (100%) – ARM-based Windows devices
High Quality (80%) – Most modern Windows PCs
Medium Quality (70%) – Entry-level or older systems
Neural Mix supports 64-bit Android and Chromebook devices. Devices using 32-bit processors are not compatible. All supported devices use a standardized Neural Mix quality level, although performance may still vary slightly depending on hardware.
Neural Mix is not currently supported in djay for Apple Vision Pro or Meta Quest.
