How do I connect an external screen or projector to djay?
djay supports external screens and projectors across macOS, iOS, Windows, Android, Vision Pro, and Meta Quest. Depending on your device, you can connect using HDMI, USB-C display output, AirPlay, or wireless casting. This guide explains the supported methods on each platform and provides clear steps for getting your visuals or video mix onto an external display.
You can connect an external screen or projector to djay using HDMI, AirPlay, or Universal Control with an iPad.
Connection options
  • HDMI: Plug your display directly into your Mac using an HDMI cable or USB-C adapter.
  • AirPlay: Use macOS Displays settings to select an AirPlay device.
  • iPad (Universal Control): Use your iPad as a secondary screen.
How to connect
  1. Open System Settings > Displays on your Mac.
  2. Confirm that both screens are detected. If they overlap, right-click and select Stop Mirroring.
  3. In djay, open Video mode, then click the screen icon in the upper-right corner.
  4. Select your external screen and choose Show to start outputting visuals.
For smoother playback, disable Screen Mirroring and keep your Mac connected via wired HDMI when possible.
