djay Pro stores all app-specific data in the following folder:
- Windows Store version:
%LOCALAPPDATA%\Packages\59BEBC1A.djayPro_e3tqh12mt5rj6\LocalState\Library\Algoriddim
- Demo version:
%LOCALAPPDATA%\Packages\Algoriddim.djayPro_ysvet2nbq0e5e\LocalState\Library\Algoriddim
You can access these folders by pasting the above path into your Explorer’s address bar.
This folder contains the following data:
- djay Preset Library.plist: cue points, 1st down beats and all other data set by the user
- Metadata: per-song analyze data (e.g. waveforms, beat grids, etc.)
- Sets: your DJ set history as displayed in the djay Pro media library
- Samples: custom audio samples (including recorded samples)
- Sampler Presets: custom audio sampler presets
