What are the differences between the TIDAL quality settings in djay?
This article explains how to customize TIDAL playback quality in djay across all platforms. Learn how to adjust streaming settings to optimize audio fidelity, reduce data usage, or improve performance depending on your setup.
TIDAL quality options​
djay lets you customize the playback quality of TIDAL tracks to match your needs. This option is supported on macOS, iOS, Windows, and Android.
There are currently three TIDAL quality modes to choose from:
  1. Normal: Offering a bitrate of 96 kbps in AAC-HE v2 format.
  2. High: Delivering audio playback at 320 kbps in AAC format.
  3. HiFi: Providing an uncompromising audio experience in FLAC format.
  • Quality changes will take effect once you load a new track from TIDAL in djay.
  • HiFi quality is only available on macOS and iOS.
Please be aware that these TIDAL quality modes may be subject to change in the future. Happy mixing!
