Which DVS-compatible mixers work with djay?
While djay supports any audio interface, mixer, and MIDI controller that is supported on the respective platform, the following DVS-compatible mixers have been pre-mapped and can be used plug-and-play with djay and DVS.
Supported DVS-Compatible Mixers
All mixers listed below are fully mapped (including performance pads) and configured automatically upon connection.
  • Allen & Heath Xone:23C
  • Allen & Heath Xone:24C
  • Allen & Heath Xone:96
  • Allen & Heath Xone:PX5
  • Denon DJ X1850 Prime
  • Numark Scratch
  • Pioneer DJ DJM-A9
  • Pioneer DJ DJM-S3
  • Pioneer DJ DJM-S5
  • Pioneer DJ DJM-S7
  • Pioneer DJ DJM-S9
  • Pioneer DJ DJM-S11
  • Pioneer DJ DJM-V10
  • Pioneer DJ DJM-900NXS2
  • Pioneer DJ DJM-450
  • RANE MP2015
  • RANE SEVENTY
  • RANE SEVENTY A-TRAK Signature Edition
  • RANE SEVENTY-TWO
  • RANE SEVENTY-TWO MKII
  • Reloop ELITE
  • Reloop RMX-95
On supported mixers, you can also use Neural Mix™ directly via the performance pads. For more information, see How do I use Neural Mix™ on supported mixers or controllers in djay?.
