While djay supports any audio interface, mixer, and MIDI controller that is supported on the respective platform, the following DVS-compatible mixers have been pre-mapped and can be used plug-and-play with djay and DVS:
Allen & Heath Xone:96 (Mac + iOS)
Allen & Heath Xone:PX5 (Mac + iOS)
Denon DJ X1850 Prime (Mac + iOS)
Numark Scratch (Mac + iOS)
Pioneer DJ DJM-S3 (Mac)
Pioneer DJ DJM-S5 (Mac + iOS)
Pioneer DJ DJM-S7 (Mac + iOS)
Pioneer DJ DJM-S9 (Mac)
Pioneer DJ DJM-S11 (Mac + iOS) * ✧
Pioneer DJ DJM-900NXS2 (Mac)
RANE MP2015 (Mac + iOS)
RANE SEVENTY (Mac + iOS)
RANE SEVENTY-TWO (Mac + iOS) *
RANE SEVENTY-TWO MKII (Mac + iOS) *
Reloop ELITE (Mac + iOS)
- Reloop RMX-95 (Mac + iOS)
These mixers are fully mapped (including performance pads) and configured automatically upon connection. You can also use Neural Mix™ directly via the performance pads on some of these mixers. For more on this, please see the FAQ for the platform you're using:
How do I use Neural Mix on supported mixers or controllers on djay for Mac?
✧ Pioneer DJM-S11: requires latest mixer firmware to work on iOS.
* Some features are not currently supported on these mixers:
- Pioneer DJ DJM-S11: waveform display
- RANE SEVENTY-TWO: waveform display, djay FX (note: requires holding SHIFT when selecting performance pad modes)
- RANE SEVENTY-TWO MKII: waveform display, djay FX (note: requires holding SHIFT when selecting performance pad modes)
