How do I connect a MIDI controller to my device and djay?
This article explains how to connect a supported MIDI controller to djay across all major platforms. You’ll learn what cables and adapters to use, how to ensure proper detection, and how to set up Bluetooth or audio configurations for smooth performance.
Introduction
You can connect a supported DJ MIDI controller to djay on any platform to unlock hands-on control of mixing, scratching, and performance features. djay automatically detects most class-compliant controllers and configures them instantly.
For a full list of officially supported controllers, visit our DJ Gear page.
Watch the video tutorial
For a quick walkthrough, watch our video tutorial on how to connect a MIDI controller to djay:
To connect your MIDI controller to djay Pro for Mac:
  1. Connect your controller to your Mac using a compatible USB cable.
  2. Power on your controller if it has an external power switch.
  3. Launch djay Pro. The app will automatically recognize the controller and load its official mapping.
If using a Bluetooth-enabled controller (like the Hercules DJControl Mix):
  1. Turn on Bluetooth on your Mac.
  2. Open djay Pro > MIDI > Connect Bluetooth Controller.
  3. Select your controller and click Connect.
Important
Some controllers include built-in audio interfaces. You can select your preferred output device in djay > Settings > Audio Devices/Configuration.
If your controller isn’t detected, disconnect and reconnect it after launching djay.
