How to set up the Traktor Kontrol S2 MK3 or S3 with djay
Follow this guide to update your firmware, enter user MIDI mode, and set up your Traktor Kontrol S2 MK3 or S3 for use with djay for Mac.
Setup on macOS
  1. Make sure your controller is running the latest firmware. Older firmware versions may not work with djay.
    Visit the Native Instruments download page and scroll to the entry for TRAKTOR KONTROL S2 MK3 or TRAKTOR KONTROL S3:
    https://www.native-instruments.com/en/support/downloads/drivers-other-files/
  2. Run the firmware installer on your Mac and complete the update steps.
  3. Fully disconnect your controller from your Mac and any power source.
  4. Hold the left FLX button (located at the top left of the jog wheel), then connect the controller to your Mac using the USB cable.
    S2 user MIDI mode
The button is located in the same place on the S3 controller
  1. The cue pads will blink green, indicating that the controller is now in user MIDI mode.
  2. Open djay Pro for Mac - djay will detect the controller and automatically pre-map all functionality, so you're ready to mix right away!
A PRO subscription is required to use the Traktor S2 MK3 / S3 with djay.
