You can connect djay Pro for Mac to any compatible external mixer. By following these steps, you will assign the djay-deck outputs to different channels of your external mixer.
- Connect your mixer with your Mac via USB. If the mixer requires a driver, make sure it's installed.
- Go to the djay Pro "Preferences…" (press ⌘ + , ) and select Devices.
- Now switch to "External" and assign the decks to the mixer, as shown below:
