Understanding DRM-protected songs in djay
djay supports most purchased tracks from the iTunes Store across all platforms. However, Apple Music streaming tracks and some older DRM-protected purchases cannot be played due to copyright restrictions. This article explains what DRM is, how it affects your library, and how to check if a track is protected.
What is DRM?​
Digital Rights Management (DRM) is a form of copy protection that limits how audio files can be used. Tracks with DRM can only be played in apps that support Apple’s protection system — djay and other third-party DJ apps cannot load them.
djay cannot remove or bypass DRM. This is controlled by the music distributor, not by your device or djay.
Which tracks can I play in djay?​
✔️ Supported​
  • iTunes Store purchases without DRM
    Most tracks purchased after 2009 are DRM-free and work in djay on all platforms.
❌ Not supported​
  • Apple Music streaming tracks
    Songs added to your library via an Apple Music subscription are DRM-protected and cannot be played in djay.
  • Older DRM-protected iTunes Store purchases
    Some tracks purchased before 2009 still contain DRM and cannot be used.
How to check if a track is DRM-protected​
You can verify a track’s protection status from within the Music app (or equivalent app on your platform):
  1. Open the Music or media library app.
  2. Right-click or long-press the track.
  3. Select Get Info or Song Info.
  4. Look for the Kind or File Type field.
If you see:
  • Protected AAC audio file → DRM-protected (not supported)
  • Purchased AAC audio file → Not protected (supported)
Why aren’t Apple Music songs supported?​
Apple Music uses streaming rights, not true ownership.
Because streaming tracks are DRM-protected, djay cannot analyze or load them for mixing.
This restriction applies across all device platforms. No third-party DJ app can load Apple Music streaming tracks.
If you have older DRM tracks​
If you purchased songs before 2009, Apple may allow you to:
  • Upgrade them to DRM-free versions (if available)
  • Re-download a non-protected version from your purchase history
You can check your Apple ID purchase history in the Music or iTunes Store app.
Next steps​
  • If a song won’t load, verify whether it is from Apple Music or an older DRM-protected purchase.
  • Consider using non-protected files, supported streaming services, or your own uploaded tracks.
