The PRO version of djay Pro AI supports a wide variety of DJ MIDI controllers suitable for DJs of all skill levels. And, if you're using one of the official controllers made for djay, then you'll have full use of all controls on your controller using the FREE version of djay out of the box!
Official djay controllers supported on the FREE version
Via simple plug and play, enjoy full use of the FREE version of djay using any one of the following official controllers made for djay:
- Reloop Beatpad 2
- Reloop Buddy
- Reloop Mixon 4
- Reloop Mixtour
- Reloop Ready
- Pioneer DJ DDJ-200
- Hercules DJControl Inpulse 200
- Hercules DJControl Inpulse 300
- Hercules DJControl Mix
- Hercules DJControl Starlight
- The Next Beat by Tiësto
Enjoy full access to all controls on your hardware. For instant access to all djay features available in the app itself, you have the option to upgrade to the PRO version of djay.
In addition to the listed controllers above, the following official djay legacy controllers are supported on the FREE version of djay:
- Reloop Beatpad
- Pioneer DJ DDJ-WeGO
- Pioneer DJ DDJ-WeGO2
- Pioneer DJ DDJ-WeGO3
- Pioneer DJ DDJ-WeGO4
- Pioneer DJ DDJ-ERGO
- Numark iDJ Live*
- Numark iDJ Live II
- Numark iDJ Pro*
- Numark Mixdeck Quad
- Casio XW-DJ1
- Casio XW-J1
- ION iDJ2GO
- Philips M1X DJ
- Vestax Spin 2
*Please note, these legacy controllers require a lightning to 30-pin adapter, which is no longer available on the market; in addition, they are not supported using USB-C.
Controllers supported on the PRO version
With the PRO subscription, along with full access to a range of advanced features in djay, you gain full native support for over 50 additional MIDI controllers.
→ Please see the full list of natively supported MIDI controllers available with a PRO subscription.
If you don't find your DJ controller on this list, feel free to reach out to our team and let us know! In addition to that, you can use djay’s easy-to-use MIDI Learn feature. With MIDI Learn, you can map any MIDI controller that may not already be natively supported directly through your iPad or iPhone, or you can change an already existing mapping in djay. Please note, to use djay’s MIDI Learn feature, an active PRO subscription is required.
