SupportHardware & ControllersLearn how to connect, configure, and use DJ controllers, mixers, and other hardware with djay. How do I connect a MIDI controller to my device and djay?Which DVS-compatible mixers work with djay?Using audio interfaces with djayUsing Neural Mix™ / stems on supported mixers and controllersHow do I MIDI map Neural Mix™ controls in djay?How to custom map a controller in djay using MIDI learnWhy don’t some features of my MIDI controller work as intended?What operation mode should I use with the Pioneer DDJ-SR / DDJ-SX in djay?How to set up the Traktor Kontrol S2 MK3 or S3 with djay
