How do I MIDI map Neural Mix™ controls in djay?
Neural Mix™ can be controlled directly on screen or through MIDI. This article walks you through how to map available Neural Mix actions using djay’s MIDI Learn tools.
Introduction
Neural Mix™ can be used through the djay interface, but there is also a suite of MIDI commands you can map to control your Neural Mix audio tracks.
You can choose a Deck or the Mixer as a Target and map Rotaries, Faders, or Buttons to control:
  • Neural Mix Filter (Instrumental / Acappella)
  • Neural Mix Volume
  • Neural Mix EQ (–12 dB to +12 dB)
  • Neural Mix Crossfader
  • Channel modes: 2 (Instrumental / Acappella), 3 (Drums / Harmonics / Vocals), or 4 (Drums / Bass / Harmonics / Vocals)
You can also map MIDI Buttons to Mute or Solo each Neural Mix component.
Keyboard Mapping
The Neural Mix controls can be mapped to any key on your keyboard.
To do this:
  1. Open the Shortcuts editor in djay's Preferences menu.
  2. Select the Target as any deck (e.g., Deck 1, Deck 2) for the desired keyboard key.
  3. Scroll down the actions list to find the Neural Mix actions.
DJ Controller Mapping
To get the full capability of djay Pro for Mac's Neural Mix AI-driven audio separation on your MIDI controller, you can set up the following available MIDI controls:
  • Neural Mix Volume
You can choose whether you'd like to use these Neural Mix controls on 2, 3, or 4 channels.
You can also map MIDI buttons to Neural Mix actions for the same channels so you can Mute or Solo each instrument.
To map each control, follow the steps below:
  1. Connect your MIDI controller to your Mac and open djay Pro.
  2. Open the MIDI menu at the top of your screen and select the controller you want to add MIDI actions to. This opens the MIDI Learn window:
  3. Move the MIDI control you'd like to add a Neural Mix action to.
  4. Choose a Deck or Mixer as the Target.
  5. Select the Neural Mix action you want to assign (eg. Neural Mix Volume).
  6. Repeat for the remaining controls.
