Video effects
Video effects apply only to the visual part of a track. You can use them on videos with sound, but the FX will only affect the video, not the audio.
You can chain up to two effects per deck, including a mix of audio and video FX (A/V).
How to access video effects​
  • Click the effect name in the Effects panel or FX section.
  • Click the Visual tab.
Video effects dropdown menu
Audio-visual (A/V) effects apply to both audio and video at the same time, creating fully synchronized effects. You can also use A/V effects on audio-only or video-only tracks.
How to access A/V effects​
  • Click the A/V tab.
You can't use FX routing with visual effects.
