How to reduce audio and MIDI latency in djay
Latency affects how quickly djay responds to your controller and how accurately your audio plays back. This guide explains the most common causes of latency and provides platform-specific steps to improve responsiveness on macOS, iOS, Windows, and Android.
What is latency?​
Latency is the small delay between performing an action and hearing or seeing the result.
There are two types:
  • Audio latency — delay between playback and what you hear
  • MIDI latency — delay between moving a control and djay responding
Latency can be caused by:
  • USB adapters/hubs that limit bandwidth or power
  • OS-level power saving
  • Bluetooth audio
  • Background apps that use system resources
  • Outdated drivers or firmware
  • Misconfigured audio settings (Windows only)
This guide explains how to improve latency based on your device and platform.
Basic troubleshooting (all platforms)​
  1. Quit and relaunch djay.
  2. Disconnect and reconnect your controller.
  3. Avoid Bluetooth speakers or headphones — they always introduce noticeable latency.
  4. Use wired audio or a controller with a built-in audio interface.
  5. Close background apps using CPU, GPU, or audio resources.
  6. Make sure djay is updated to the latest version.
  7. Install firmware updates for your controller if available.
  8. Try a different USB cable, port, or official adapter.
Platform-specific steps​
1. Use wired audio​
Bluetooth and AirPlay add unavoidable latency.
Use:
  • Wired headphones
  • A USB audio interface
  • A DJ controller with built-in audio output
2. Use a reliable USB connection​
For controllers:
  • Prefer a direct USB connection to your Mac
  • If needed, use a powered USB hub
  • Avoid long or unshielded USB cables
3. Close background applications​
Video apps, browsers, and audio tools can affect responsiveness.
4. Restart your Mac​
If CoreAudio becomes unstable, a restart often restores smooth performance.
Important info
Bluetooth audio introduces unavoidable latency on every platform.
For the best performance, always use a wired audio connection or a controller with built-in audio outputs.
