Preparing your device for uninterrupted DJing in djay
Getting interrupted by a call, message, or system alert during a DJ set can disrupt your flow.
This guide shows you how to silence notifications, reduce distractions, and keep your device performance-ready while using djay.
Preparing your Mac for uninterrupted DJing​
Enable a DJing Focus mode​
  1. Open System Settings > Focus.
  2. Tap +, choose Custom, and name it DJing.
  3. Set Allowed Notifications for both People and Apps to None.
  4. Turn off Time Sensitive Notifications.
  5. (Optional) Set the Focus mode to activate automatically when you open djay.
If you already created a DJing Focus mode on your iPhone or iPad, it will automatically sync to your Mac if you’re using the same Apple ID.
Additional tips for uninterrupted DJing on macOS​
  • Go to System Settings > Sound > Sound Effects and turn off Play user interface sound effects.
  • Reduce or mute the Alert volume slider.
  • Quit messaging apps such as iMessage, Slack, or Discord.
  • Disable features like Time Machine backups or other scheduled notifications.
  • Keep your Mac connected to power throughout your performance.
Universal best practices
These steps improve reliability on any device:
  • Always enable Do Not Disturb or a custom Focus mode before your set.
  • Silence notifications and system sounds globally or per-app.
  • Pause notifications from messaging and social apps.
  • Disable auto-lock or extend display timeout.
  • Keep your device fully charged or plugged in throughout your session.
