How to fix audio dropouts and glitches in djay
Reliable audio performance is crucial when DJing. Audio dropouts and glitches can occur for many reasons, including unstable USB connections, outdated software, system load, or incorrect hardware setup. This guide walks you through the essential steps for each platform to ensure the best possible performance in djay.
Troubleshooting audio issues​
1. Keep macOS, djay, and firmware up to date​
  • Update macOS to the latest version.
  • Update djay through the Mac App Store.
  • Check your controller or audio interface manufacturer’s website for:
    • Firmware updates
    • Updated macOS drivers (if required)
Most modern DJ controllers are class-compliant on macOS and do not require separate drivers. Only check for drivers if the manufacturer explicitly provides them for your device.
2. Check your USB connections​
USB instability is one of the most common causes of audio dropouts.
Try the following:
  1. Use a different USB cable—preferably shielded.
  2. Avoid placing USB cables near power adapters or speakers.
  3. If you must use a hub, use a powered USB hub.
  4. If possible, connect your controller/audio interface directly to your Mac.
3. Close unnecessary apps​
Background applications can consume CPU, RAM, and disk resources.
  • Quit other apps, especially browsers, video apps, or any background syncing services.
  • Disable unnecessary utilities that run in the menu bar.
4. Wait for Spotlight to finish indexing external drives​
If you connect an external drive:
  • macOS may temporarily index it (Spotlight), which increases disk activity.
  • Audio glitches can occur during this time.
Wait until indexing completes before performing.
5. Avoid running resource-intensive tasks​
  • Rendering video
  • Large file transfers
  • Cloud syncing (Dropbox, OneDrive, iCloud Drive)
Such tasks can interrupt stable audio processing.
On macOS, buffer size and sample rate cannot be changed within djay. djay uses the system audio settings automatically.
Additional Tips​
Try a different audio device​
If possible, test:
  • A different USB controller
  • A different audio interface
  • Your device’s built-in speakers/headphones
This helps determine whether the issue is hardware-related.
Restart your device​
A restart can clear temporary system resource issues that affect audio processing.
Test with local music files​
Streaming tracks require a stable internet connection.
Try local files to rule out network-related issues.
