The latest version of djay for Mac, djay Pro, is available for download through the Mac App Store.
djay Pro is available as a free download that offers all the core features needed to start mixing right away. After downloading the free version, you have the option to purchase a PRO subscription that gives you instant access to all advanced features of djay Pro, such as Neural Mix and Automix. The PRO subscription also allows access across your Mac, iPhone, iPad, Windows*, and Android* devices.
If you'd like to give it a try first, we offer a 7-day free trial of the PRO subscription, giving you full access to all PRO features.
Please note that djay Pro requires macOS 10.15 (Catalina) or later. You can check djay version and macOS compatibility here: Which macOS version is compatible with my version of djay?
If you have an older version of macOS that djay Pro is not compatible with, please contact our Support Team so they can assist you further with one of our older versions of djay (if available).
* Some features in djay Pro for Mac are not yet available in djay Pro for Windows and djay for Android.
