What's included in the PRO subscription of djay
djay is available as a free download on all major platforms, letting you start mixing instantly, with a free trial to explore everything djay Pro has to offer.
A PRO subscription unlocks the full creative toolkit: Neural Mix™, advanced performance modes, expanded media management, deep hardware integration, and an extensive library of 1,000+ loops, samples, and visual content packs. Whether you’re practicing, performing, or creating, djay Pro gives you the complete professional DJ experience across all your devices.
What djay PRO Unlocks
djay gives you everything you need to start mixing the music you love right away. Subscribing to djay PRO takes your experience further with a powerful set of creative, performance, and library features.
Your djay PRO subscription works across all supported platforms, giving you access to advanced features on every device you use.
Neural Mix™ – isolate vocals, drums, and instrumentals in real time
Automix – AI-powered automatic DJ mixes
Sampler & Looper – add beats, textures, and live remix elements
Crossfader FX – perform expressive, dynamic transitions
Video Mixing* – mix music videos, add overlays, and output visuals to an external screen
Recording – capture your mixes in high-quality audio
Content Packs – 50+ audio effects, 1000+ loops, samples, visuals
4-Deck Mode* – layer multiple tracks and stems
Pre-cueing with headphones
Plug-and-play support for 100+ MIDI controllers across Pioneer DJ, AlphaTheta*, Reloop, Hercules, Denon DJ, Numark, and more
Digital Vinyl System (DVS) for turntable control
Advanced MIDI Learn to customize mappings
Full media library editing – edit track information and manage your collection with flexible tools
Custom playlists and preparation tools – create and organize playlists to prepare for any performance
USB library export - export your playlists and tracks from djay directly to a USB or SD drive for use on other devices or DJ systems
Library Batch Analysis - background analysis of your tracks
Features marked with * differ by platform
- Video Mixing – available on macOS and iOS
- 4-Deck Mode – available on macOS, iOS, and Windows
Recording is not available when using streamed tracks, and Neural Mix cannot be used with music streamed from Apple Music or Spotify.
