How to purchase djay PRO
djay is a free-to-download app with an optional paid subscription that unlocks our line of PRO features including Neural Mix™, Automix, and many more.
Your djay PRO subscription works across macOS, iOS, Windows, and Android when you sign in with your djay account. More details on setting up your djay account can be found here.
Follow the steps below to download djay Pro, start a 7-day free trial, and subscribe to unlock advanced features across all your devices.
- macOS
- iOS
- Windows
- Android
- Apple Vision Pro
- Meta Quest
How to purchase djay PRO on macOS
You can download djay for Mac directly from the Mac App Store.
The app is free to download and includes all the core features you need to start mixing right away.
- Open the App Store on your Mac.
- Make sure you’re signed in with the correct Apple ID in the App Store.
- Search for “djay” and click Get to download it for free.
- After installing, open djay from your Applications folder or Launchpad.
Once installed, you can upgrade to a PRO subscription to unlock advanced features such as Neural Mix™, Automix, and more. You can find the full list of features here.
Your PRO subscription gives you full access across macOS, iPhone, iPad, Windows, and Android — all connected through your djay account.
If you’d like to explore the PRO features first, you can start a 7-day free trial, which offers full access to everything included in the subscription.
djay PRO requires macOS 10.15 (Catalina) or later.
How to purchase djay PRO on iOS
You can download the djay app directly from the App Store.
- Open the App Store on your iPhone or iPad.
- Make sure you’re signed in with the correct Apple ID.
- Search for “djay” and tap Get to download it for free.
- After installing, open djay from your Home Screen.
Some PRO features may not be available on Windows and Android
If you decide not to continue after the trial, cancel at least 24 hours before the trial ends to avoid being charged through the App Store.
How to purchase djay PRO on Windows
You can download djay for Windows directly from the Microsoft Store.
The app is free to download and includes all the essential features you need to start mixing immediately.
- Download djay Pro from the Microsoft Store.
- Open djay Pro for Windows.
- Click Start Free Trial.
- Sign in with your Microsoft account when prompted.
- Select and confirm your preferred payment method.
- Once your payment method is confirmed, djay Pro will notify you that your PRO subscription is active.
djay offers a 7-day free trial that includes full access to everything in the PRO subscription. You can find the full list of Pro features here.
djay Pro for Windows requires Windows 10 (version 21H1) or later.
How to purchase djay PRO on Android
You can download djay for Android from the Google Play Store.
The free version includes all the essential tools you need to start mixing right away.
- Open the Google Play Store on your Android device.
- Make sure you’re signed in with the correct Google account.
- Search for “djay” and tap Install to download it for free.
- After installing, open djay from your app drawer or Home Screen.
While we strive to maintain consistent functionality across all platforms, some features may differ due to platform-specific development. We’re actively working to align the Android experience with djay on iOS, Mac, and Windows.
djay for Android requires Android 10 or later.
How to purchase djay PRO on Apple Vision Pro
You can download the djay app directly from the App Store on Apple Vision Pro.
- On your Vision Pro headset, open the App Store.
- Search for “djay – DJ App & AI Mixer” and select the app.
- Download and install djay.
- After installing, open djay from your Apps view.
Once installed, you can upgrade to a PRO subscription to unlock the full djay Pro feature set.
- In djay, tap the option to start a PRO subscription.
- Choose a monthly or annual plan.
- Follow the on-screen instructions to confirm your subscription purchase (billing is handled through your Apple ID).
If your subscription was purchased via Apple ID, it includes Vision Pro, iOS, and macOS. It does not include Windows or Android.
If you already have a djay Pro subscription on another Apple device, make sure you’re signed in with the same Apple ID in Vision Pro’s system settings so your subscription can be recognized.
How to purchase djay PRO on Meta Quest
The Meta Quest version of djay is built specifically for VR and mixed-reality experiences.
You can install djay directly from the Meta Horizon Store on Meta Quest.
- On your Quest headset, open the Meta Horizon Store.
- Make sure you’re signed in with the correct Meta account.
- Search for “djay” and select the app.
- Purchase the app (one-time purchase) and install it.
- Once installed, launch djay from your Apps library.
On Meta Quest, djay is a one-time paid app purchased directly from the Meta Horizon Store. This license is separate from djay Pro subscriptions on other platforms, so an existing PRO subscription on macOS, iPhone, iPad, Windows, Android, or Apple Vision Pro does not carry over to Meta Quest.
