Neural Mix™ control vinyl
Neural Mix™ Control Vinyl takes stem separation to the turntables. Available on the B-side of official djay Control Vinyl records, it lets you scratch, mix, and perform with isolated vocals, instrumentals, or percussive and tonal elements. It’s a powerful way to bring Neural Mix into traditional vinyl setups while keeping the feel of classic DJing.
Control vinyl settings
The B-side includes three tracks:
  • Track 1: Standard 5-minute timecode signal.
  • Track 2: 5-minute Neural Mix isolation of instrumental and acapella.
  • Track 3: 5-minute Neural Mix isolation of percussive and tonal elements.
To choose your desired Neural Mix™ mode, go to Settings > DVS and select:
  • Instrumental / Acapella
  • Percussive / Tonal
Keep your records and turntables clean and calibrated for optimal performance. Use a carbon fiber brush to remove dust, and ensure your tonearm and counterweight are properly balanced.
