Connecting a MIDI controller
Using a MIDI controller with djay Pro gives you hands-on control over your mix, from triggering cue points to adjusting EQ and effects in real time. Thanks to plug-and-play support, officially supported controllers work right out of the box, while Bluetooth options make wireless setups simple and portable.
You can view the full list of officially supported controllers on the Algoriddim DJ Gear page. Setting up an officially supported controller is quick and easy thanks to plug-and-play support.
How to connect a supported MIDI controller​
  1. Make sure djay Pro is open and ready.
  2. Connect your controller via an available USB port and power it on using the ON/OFF switch or power button.
  3. When the controller is detected, follow the on-screen instructions or go to MIDI > Configure.
  4. You should now be able to control djay Pro using your hardware.
When you connect a controller, djay will automatically apply your last saved audio configuration that includes the connected controller. This ensures your setup always works out of the box.
In some cases, you may need to adjust the audio routing manually—for example, if your setup routes all audio through a different audio interface than the connected controller. If your configuration doesn’t load as expected, check that it includes the connected controller.
How to connect a supported Bluetooth controller​
djay Pro supports a selection of Bluetooth-enabled DJ controllers, such as the Hercules DJControl Mix, using the app’s built-in Bluetooth Configuration tool.
Wireless control can be especially useful for casual setups, practice sessions, or mobile DJing where portability and fewer cables are essential.
Connecting a MIDI controller via Bluetooth
  1. Enable Bluetooth on your Mac (System Settings > Bluetooth).
  2. Plug your controller into a power source.
  3. Set the controller to pairing mode—usually indicated by flashing LEDs (check your controller's manual if unsure), unless done automatically.
  4. Open djay Pro.
  5. In the menu bar, click MIDI > Connect Bluetooth Controller.
  6. In the Bluetooth Configuration window, select your controller from the list.
  7. Click Connect.
Once connected, you’ll be able to control djay wirelessly from your controller.
If your preferred controller isn’t supported, you can still use it with djay by mapping it manually. djay Pro supports a wide range of MIDI-compatible devices through its built-in MIDI mapping system. Go to the MIDI Mapping section for more details.
Check the list of officially supported controllers to see which models officially work with djay Pro for Mac and support Bluetooth.
