Waveform options
The Waveform options let you customize how waveforms are displayed and control zoom. These tools help you personalize the interface and improve precision while mixing.
Accessing waveform options​
  1. Make sure waveforms are displayed.
  2. Tap the dropdown menu in the corner of the waveform next to the deck number.
Waveform options
High Contrast​
High contrast increases the visibility of the waveform by boosting contrast against the background.
Zoom​
Zoom adjusts the level of detail you see in the waveform, helping with manual beatmatching and precise cue placement.
