Mute FX
Mute FX adds polish to your mixes by replacing abrupt cuts with smooth echo tails when you mute or solo Neural Mix™ stems. Instead of dropping sounds instantly, stems fade out with an echo—making your transitions feel more natural and professional.
How to use Mute FX​
  1. Open the Mute FX dropdown menu in the Neural Mix™ toolbar.
  2. Click the Mute FX button to activate.
  3. Choose when you want the Echo Out to begin:
    • 1 beat
    • ¾ beat
    • ½ beat
  4. When you mute or solo stems, an echo tail will now play instead of cutting the sound abruptly.
Neural Mix Mute FX
