Crossfader FX
Crossfader FX adds effects to your transitions—going beyond a basic left-to-right volume fade. Use Echos, Filters, Tremolos, Sweeps, Risers, and Neural Mix™ to create smooth, cinematic fades or wild, creative blends. You can also control the duration of the transition by selecting the number of bars.
Crossfader FX is perfect for adding flavor to transitions automatically, without worrying about precise EQ or volume control.
Crossfader FX
Looking for an easy way to match tracks with different BPMs? Try Tempo Blend. Just load tracks with different tempos onto each deck, and Tempo Blend will automatically sync them as you move the crossfader. It’s a great way to switch up genres and tempos while keeping the energy going.
Crossfader FX tempo blend
Want more precise control? Use Neural Mix™ FX to separate and blend stems (such as drums, vocals, and harmonics) in real-time. With Neural Mix™, you can isolate and manipulate parts of a track on the fly—perfect for creative transitions, mashups, or minimalist edits.
If you're practicing manual beatmatching, consider turning Crossfader FX Sync Mode off to avoid unexpected tempo changes.
Crossfader FX settings
How to use Crossfader FX​
  1. Load your tracks onto the decks.
  2. Tap the dropdown icon next to the crossfader to open Crossfader FX.
  3. Toggle the Crossfader FX button to enable it.
  4. Choose the effect(s) you want to use.
  5. Select the number of bars for the transition length.
  6. With both tracks playing, either move the crossfader or tap the Mix now button.
djay will now blend the tracks and effects, creating smooth and dynamic transitions that are uniquely yours.
You can quickly tell when Crossfader FX is active by looking at the crossfader—a blue line will appear down the center when it’s turned on.
