Cue loops
Cue loops let you save a loop together with a cue point, so you can instantly return to a section and loop it during your mix. This is useful for creating reliable mix-in points, building tension, or extending breakdowns.
When you create a loop and assign a new cue point, the loop is stored with that cue. Triggering the cue point will automatically activate the loop.
A Cue Loop icon appears on the right side of the assigned cue point pad. You can trigger this button to exit the loop, or use hardware mapped to the cue loop commands.
How to create a cue loop​
  1. Go to the Loop section and create a new loop by tapping an empty pad.
Cue loop
  1. While the loop is repeating go to the cue section and create a new cue point by tapping an empty pad.
Cue loop
  1. You will now find a cue point and cue loop saved to the same pad.
