djay Pro for Windows
Welcome to the djay Pro for Windows user manual​
Whether you're just starting out or looking to take your DJing to the next level, this manual is your guide to mastering djay Pro for Windows.
Inside, you’ll find clear, step-by-step instructions covering everything from basic mixing and library setup to advanced performance tools, hardware integration, and creative techniques. It's designed to help you get comfortable quickly—and to keep growing as a DJ.
You can read it front to back, or jump into specific sections when you need help or inspiration. Either way, this manual is here to support your journey, whether you're mixing your first tracks or preparing for your next set.
Enjoy!
