Gesture Control, a feature available in djay on iPad, uses AI-powered hand-tracking technology to allow you to mix music through hand gestures without the need to physically touch your device.
This powerful feature allows you to mix, scratch, and apply FX through "Air DJing", and it is compatible with the following iPads:
- iPad Pro 11‑inch
- iPad Pro 12.9‑inch (3rd generation or later)
- iPad Air (4th generation or later)
Please note that Gesture Control requires iOS 14 and later. In addition, it requires a PRO subscription and is included for all existing subscribers.
You can activate Gesture Control in Classic View from the Dashboard in djay. For more information about how to use Gesture Control, see How do I use Gesture Control on djay for iOS?
Watch the Intro Video to get an idea of how it works, or to see it in action, you can check out DJ Ravine's DJ Mix Video.
