Our team is excited to introduce many new features for Mac users with the release of djay Pro AI. We've taken a lot of the feedback and suggestions from djay users in our community into consideration to provide the necessary tools to open up a new world of creative possibilities for DJs.
Rebuilt from the ground up while incorporating our breakthrough AI technology, Neural Mix™, here are just a few of the new features you'll find:
- Neural Mix™
- Neural Mix™ track faders (2- and 3-band)
- Neural Mix™ waveform separation (2- and 3-band)
- Neural Mix™ 3-band crossfader
- Neural Mix™ EQ routing
- Neural Mix™ FX routing
- Neural Mix™ Bounce Loop routing
- Neural Mix™ Instant FX pads
- Neural Mix™ channel configurations to suit different genres and mixing styles (e.g. “Instrumental – Acapella” separation for Hip Hop, “Drums – Harmonic – Vocals” for Dance, or “Drums – Bass – Melodic” for Electronic music)
- Looper music performance mode with up to 48 quantized audio and video loops at once. PLUS, over 1GB of samples, loops, and videos, with much more added in the future
- Sequenced sampler
- Improved Automix with start and end cue point options
- Improved single deck mode
- Improved filter & FX
- Improved waveform settings:
- Waveform orientation and positioning
- Waveform beat numbers in detail waveforms
- Waveform minute markers in overview waveforms
- Improved music library view management (i.e., ability to hide music sources you're not using)
- Isolator EQ option
- Filter resonance setting
- Support for Open Key format
- Dipped crossfader curve option
- Automatic saving of per-controller audio device settings
- Support for monitor, Sampler, and Looper output with external mixer mode
- New controller mappings:
- RANE TWELVE MKII
We invite you to check out the introductory video for djay Pro AI for Mac here.
