Logo
  • Home
  • DJ Apps
  • DJ Gear
  • DJ School
  • Support
  • Company
  1. Algoriddim Support
  2. djay for iOS
  3. DJ Hardware
Can I have more than one MIDI Mapping for my controller?
Yes, you can create and edit several mapping configurations for the same controller to fit your needs. You’ll find these by tapping on the name of your controller at the top of the MIDI Learn editor.
For more details about how to use the MIDI Learn editor for adding and editing mappings, see the following FAQ: How do I configure a MIDI controller using MIDI Learn on iOS?
Was this article helpful?
3 out of 6 found this helpful
Have more questions?
Check out the Algoriddim Community or contact us.
Return to top
Articles in this section
  • Which DJ MIDI controllers are supported on djay Pro AI for iOS?
  • How do I connect a DJ MIDI controller to my iPhone or iPad?
  • How do I calibrate turntables for DVS in djay for iOS?
  • How do I use Neural Mix on supported mixers or controllers on djay for iOS?
  • How do I set up the Traktor Kontrol S2 MK3 or the Traktor Kontrol S3 with djay for iOS?
  • How do I set up the DJ TechTools Midi Fighter Twister with djay for iOS?
  • How do I MIDI map a controller on djay Pro AI for iOS?
  • How do I MIDI map Neural Mix™ controls in djay Pro AI for iOS?
  • Can I have more than one MIDI Mapping for my controller?
  • I already mapped this controller on my computer. Can I use the same MIDI mapping file on my iPhone/iPad?
See more
Sign up for our newsletter
I would like to read about the latest and greatest on the djay product line by Algoriddim. If I should change my mind, I can unsubscribe at any time. Further information can be found in the privacy policy.
DJ Apps djay Pro for Mac djay Pro for Windows djay for iOS djay for Android Neural Mix Pro
DJ Gear DJ Controllers
DJ School DJ Tutorials
Company About Jobs News Press
Support Contact Us FAQs Community
Logo
© algoriddim GmbH
• All rights reserved • Imprint • Privacy Policy
Mac OS, Mac, iPad, iPhone, iPod touch, iTunes, iTunes Store, and AirPlay are trademarks of Apple Inc, registered in the U.S and other countries.
Multi-Touch is a trademark of Apple Inc.
