Faders and knobs are used across the djay interface to give you full control of your track's playback. To allow you to quickly reset the parameters controlled by these faders and knobs, djay offers several quick-actions that we'll describe below.
Mouse Actions
Double-clicking on a fader or a knob will reset the parameters to its default base setting, or to 0%.
Alternatively, holding the Ctrl-button while clicking will also instantly reset the value to its default setting.
Keyboard Actions
To reset all sliders at once for one deck, you can use the following keyboard shortcuts:
- Deck 1: Shift-Alt-A
- Deck 2: Shift-Alt-L
