You can export your recordings made with djay on iPad & iPhone to your computer using iTunes File Sharing:
- Connect device to your Mac or PC.
- Select your device in iTunes.
- Click the Apps tab and scroll down to the bottom of the page.
- Under the File Sharing section select djay 2/Pro to retrieve your recordings.
- Drag and drop recordings from the Documents list to a folder on your computer.
