You can transfer music from your Mac or Windows computer to your Android device using a USB cable. After transferring the music to your device, you can automatically play it with djay for Android.
Mac
- Download and install Android File Transfer on your Mac.
- If your screen is locked, unlock your screen.
- Connect your computer to your device using a USB cable. If you need to select a USB connection option on your device, choose Media device (MTP).
- Locate music files on your computer and drag them into your device's Music folder in Android File Transfer.
Windows
- Locate music files on your computer and drag them into your device's Music folder.
Note: djay for Android does not support Google Play Music (streaming service) songs. Please transfer your music via Android File Transfer (Mac) or via MTP (Windows) as described above.
