To import your crates/playlists from Serato or Traktor, please follow these steps:
Open iTunes
Create a blank playlist
Open the playlist/crate you want to export in Serato or Traktor
Select all tracks in the playlist/crate (Cmd + A)
Drag and drop the selected tracks into the iTunes playlist
The playlist will automatically be synchronized to djay
Note: djay does not currently support importing cue points and beat grids stored in the ID3 tag.
