To reset your djay settings please follow these instructions:
- Open the Terminal app on your Mac (located in the Applications > Utilities folder).
- Depending on your version of djay please copy and paste the following command into the Terminal and press "enter":
- djay Pro (downloaded from the Mac App Store):
defaults delete com.algoriddim.djay-pro-mac
- djay Pro (downloaded from the Algoriddim website):
defaults delete com.algoriddim.direct.djay-pro-mac
- djay 4:
defaults delete com.algoriddim.djay3
- djay 3:
defaults delete net.algoriddim.djay
Please note that all of the following settings won’t be affected, as these are stored separately:
- song metadata like BPM, beat grid, cue points
- history
- recordings
- samples and sample presets
- video image and text effects
- MIDI mappings
