Below you'll find the steps to reset all djay Pro AI settings back to the original default settings. If you have an older version of djay, you'll find the corresponding reset command at the bottom of this article.
- Open the Terminal app on your Mac (located in the Applications > Utilities folder).
- Copy and paste the following command into the Terminal window and press "Enter":
djay Pro AI
defaults delete com.algoriddim.djay-iphone-free |
And that's it! Next time you launch djay Pro AI, you'll find all settings have been restored to default. Please note that the following settings in djay Pro AI won’t be affected, as these are stored separately:
- Song metadata like BPM, beat grid, cue points
- History
- Recordings
- Samples and sample presets
- Video image and text effects
- MIDI mappings
If you're using one of the older versions of djay, you'll find the command to copy/paste in the Terminal app below:
djay Pro 2
If you downloaded the app from the Mac App Store:
defaults delete com.algoriddim.djay-pro-2-mac |
If you downloaded the app from the Algoriddim website:
defaults delete com.algoriddim.direct.djay-pro-2-mac |
djay Pro 1
defaults delete com.algoriddim.djay-pro-mac |
defaults delete com.algoriddim.direct.djay-pro-mac |
djay 4
defaults delete com.algoriddim.djay3 |
djay 3
defaults delete net.algoriddim.djay |
