- Make sure that your AirPlay station is in the same Wi-Fi network as your iPad or iPhone.
- Open the settings in djay using the “gear” icon.
- Tap the AirPlay icon that shows up next to the master volume slider and select your AirPlay station:
If the AirPlay icon doesn’t show up next to the master volume slider, then djay can’t find your AirPlay station. In this case, please confirm that your AirPlay station is in the same Wi-Fi network as your iPad or iPhone and make sure that AirPlay works in the "Music" app.
Note that playing music through AirPlay adds latency to your audio. We recommend using AirPlay with djay's Automix feature.
